PENDING WSUS Post installation task failure
  • Thread starter Thread starter Krish
  • Replies Replies 5
  • Views Views 6K
Krish
I have tried multiple times to install WSUS successfully not installed it’s showing error
Server connection and space and commication good
Why that error happened literally however how can install properly kindly give me valuable suggestions
https://snipboard.io/5ymgf3.jpg
I am not sure about the exact solution but you can try the below steps.
  • Uninstall WSUS completely from server manager.
  • Remove WSUS application pool in IIS.
  • Renamed C:\program files\update services folder.
  • Removed WID in C:\window\WID\Data: SUSDB.mdf and SUSDB_log.ldf
Now install the WSUS role and launch the post installation tasks.
I
Tride multiple times but no luck
Is there any alternative options to the fix
What exactly does the log say?
Thank you, Garth,
So, I did the following steps before installing WSUS.
  • Uninstall WSUS completely from the server manager.
Logs are attached.
mrdany
