SOLVED what is the difference between WQL and SQL query
Harshit Pandey
Hi, I am trying to understand the diferrence between SQL and WQL query. I know they are not same but which is one is more easy and when to use these ?
WMI provides its own query language that allows you to query managed objects as data providers. WMI Query Language (WQL) is essentially a subset of SQL (Structured Query Language) with minor semantic changes. WQL does have extensions that support WMI events and other features specific to WMI. WQL is the basis for Configuration Manager queries, whereas SQL is used for ConfigMgr reports.
WQL is a subset of SQL, thus everything in WQL is also in SQL. The only real distinctions, from a user perspective, are the keywords. Also note that views are a feature of both SQL and WQL and are not specific to either.
Best Example of this is Configuration Manager collections are based on WQL queries
One important advantage of WQL is that a WQL query can return WMI objects as well as specific properties.
Because management applications such as the Configuration Manager console interact with WMI objects, WQL queries can return result sets that you can use within the ConfigMgr infrastructure.
SirTimbit
