SOLVED SCCM Client installation (push) failure
VincentD
I'm struggling with SCCM Client installation push to install/upgrade clients in DMZ. With SCCM CB environment, from Primary site to MP/DP in DMZ.
I set up the DMZ boundaries, and enable the CPI (with an account that has local admin on the clients) , check the CCM.log but nothing happened.
I right-click on a discovered machine CLIENTX02 and "install client" then I saw movement in CCM.log :
---> Created service "ccmsetup" on machine "CLIENTX02". SMS_CLIENT_CONFIG_MANAGER 2019-05-30 2:27:49 PM 9208 (0x23F8)
---> Started service "ccmsetup" on machine "CLIENTX02". SMS_CLIENT_CONFIG_MANAGER 2019-05-30 2:27:49 PM 9208 (0x23F8)
---> Deleting SMS Client Install Lock File '\\CLIENTX02\admin$\SMSClientInstall.PR1' SMS_CLIENT_CONFIG_MANAGER 2019-05-30 2:27:49 PM 9208 (0x23F8)
on the CLIENTX02, the CCMSETUP.log is there but I see the following errors and nothing get installed (see attached log)
the MP/DP are :
SERVER02.Mydomain.Contoso.CA
SERVER03.Mydomain.Contoso.CA
DMZSERVER01.DMZdomain.Contoso.CA
but because of FW rules only the DP/MP (DMZSERVER01) in the DMZ should be accessible for my DMZ client CLIENTX02
Can you please help me with this issue?
Thanks in Advance
It is likely a Firewall issue as the log clearly show that is can't talk to your DMZ MP. the operation is timing out.
Checked FW ports for port 80. it was ok. Finally, after rebooting the DMZSERVER01 DP/MP the clients started the communication and install was successfull. It was maybe a pending restart related to IIS?
chew
