PENDING sccm 2012r2 cu5 issue pxe
matteu
Hi
I have an issue with a specific configuration of SCCM 2012R2 CU5 (no SP1) standalone.
vlan A : sccm with DP and pxe (on the same server)
vlan B : DHCP server
vlan C : client
I make a standard configuration except for :
iphelper + option 66 fqdn of the sccm server and 67 smsboot\x64\wdsnbp.com
When I push f12 on my client I receive ip adress and then blue screen with this error
http://prajwaldesai.com/sccm-error-code-0xc000000f-boot-configuration-data-missing/
Follow these steps don't help me to fix this issue !
smspxe.log
RequestMPKeyInformation: Send() failed. SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
Failed to get information for MP: http://aaa.test.c. 80004005. SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
PXE::MP_InitializeTransport failed; 0x80004005 SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
PXE::MP_LookupDevice failed; 0x80004005 SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
PXE Provider failed to initialize MP connection.
Unspecified error (Error: 80004005; Source: Windows) SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
Failed to get information for MP: http://aaa.test.c.dam.c. 80004005. SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
PXE::MP_ReportStatus failed; 0x80004005 SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
PXE::CPolicyProvider::InitializeMPConnection failed; 0x80004005 SMSPXE 12/12/2016 11:01:47 12448 (0x30A0)
I don't use MP https
Try this and let me know if it helps :-
1) Uncheck the enable PXE option on the distribution point. Remove the Windows Deployment service.
2) Remove boot images from your distribution point
3) After few minutes delete %windir%\temp
4) If WDS is uninstalled correctly, reboot the server.
5) Rename the remoteinstall folder to something else.
6) Reboot the server.
7) Add the PXE point again by checking the box on the distribution point properties. Check the distrmgr.log and see if the remoteinstall folder reappears..
Replicate the boot image to the DP again. After they land you can try running an F12 and it should roll smoothly.
landry
