PENDING Install Adobe Pro DC through SCCM
Markyb
HI all,
I'm fairly new to packaging and I am having issues deploying Adobe Pro DC through SCCM as an application. I'm pointing the install to:
SCCM Server Name\SoftwareLibrary\Adobe\AdobeDC_Pro_18_A01\Source\Adobex64\Build\adobex64.msi. The install is using the the silent switch.
I then do everything as normal, i.e distribute the content, then deploy. Then the install just hangs on installing. The logs files show that the deployment has been picked up, but it never installs. Am I using the correct install path?
Any help would be great.
Hi All,
Could you please help me with the solution for this issue , I am also facing this issue.
I have used the setup.exe and the below command
setup.exe --silent --ADOBEINSTALLDIR="C:\Program Files\Adobe Creative Cloud" --INSTALLLANGUAGE=en_GB
Getting the error as Unmatched exit code (5) is considered an execution failure.
Is there any other way to deploy it. Kindly help.
Error 5 - Access denied.
This is really a question for Adobe. Only they know how their setup works.
Aymendakout
