PENDING Help
Mohammed 1009
Active Member
Hi sr i use vm lab i download wsus version 3.0 sp2v4.30319 and sup role have problem in sync between sccm and wsus
Hi Mohammed,
Make sure that the WSUS service is UP and check the following log files under "SCCM Install directory\Microsoft Configuration Manager\Logs":
  • WCM.log
  • WSUSCtrl.log
  • wsyncmgr.log
Hi Mohammed,
  • WCM.log
  • WSUSCtrl.log
  • wsyncmgr.log
I give look it is fine no error now but in sccm console software update no veiw anything
Hi sr cm do you mean sccm ver 1902
Wsus should i selection all update that download in wsus give approved
1902 is an old version you really should upgrade to 2002.
WSUS 3.0 was for Windows 2003 and Windows 2008(???). I hope that you are not using either of those with CM 1902.
I will upgrade CM i have server 2016 datacenter how its up to day update
The news this sync whitout any error but nothing in CM showing all Software update i hope you get my question
Under Software Library > Software Updates > All Software Updates, click Synchronize Software Updates in the top ribbon.
You can check the wsyncmgr.log file for more details.
landry
