PENDING Automatic site-wide client push installation does not work
I installed SCCM 2012 R2 from scratch in my test domain environment. Having done all you did automatic site-wide client push installation does not work at all. In ccm.log there is no single entry about successful/failed installation as if automatic site-wide client push installation is not enabled. Meanwhile (just in case) I created new subnet in AD Sites and Services (192.168.8.0/24) and assigned it to Default-First-Site-Name and now I am waiting to see if anything will change.
Try using the IP address ranges instead of subnets. If there is no entry in ccm.log file then the client push is not working.
Is this some bug or something is misconfigured? Current boundary is Default-First-Site-Name (Active Directory site type) and it was created automatically after Active Directory Forest Discovery was enabled. Why on all computers with IP address in subnet 192.168.8.0/24 (assigned to Default-First-Site-Name) installation of client is not initiated?
For this Query , below is the answer
Because,
Ip address must have a subnet to help several facilities to send message to Main primary site about
Replication, Authentication and Service location for any application policies apply through GPO
Now, if you have created subnet and assign to default, are you still does not see any entry in ccm.logs.. Please update us
All test domain computers are on subnet 192.168.8.0/24, after creating that subnet in AD Sites and Services and assigning it to Default-First-Site-Name site client's installation finally started on all computers where they should so (servers and workstations - not site servers and domain controllers). Each computer was shown in ccm.log and after a while all these computers appeared in console as computers with installed client. Obviously without subnet-site mapping in AD there were no computers belonging to AD site hence no client installation took place. I made simply oversight but eventually I solved problem.
Site membership of domain computer is vital, I know that of course. AD, Exchange, SCCM and other technologies rely heavily on site concept. Simply I have forgotten to create mapping.
Thank you Maunil, by the way may I ask you something (or to post new thread) about installing/unistalling Office 2016 using SCCM 2012 R2. I have trouble with command to uninstall it - setup.exe /uninstall ProPlus /config .\uninstall.xml.
Hi All
I am also having same issue, auto client push installation not started yet, I just checked all subnets are already created and assigned to sites. no logs were created in ccm.log for even trying client installation. if I push client manually then it will be installed successfully, plz help.
ajames
