PENDING System Center does not detect required updates
  • Thread starter Thread starter TecnicoOne
  • Replies Replies 5
  • Views Views 5K
TecnicoOne
Good Morning,
I have a problem apparently with System Center, which after having synchronized all the updates, it shows me everything as (0) in required. This causes the ADR (Automatic Deployment Rules) not to detect what each Windows 10 computer or client really needs.
I can deploy other updates from Windows Server 2019, Office, Defender Definitions, but not from Windows 10. To investigate a bit since I am new to this world of System Center, I opened the Wsus console and verified that the computers I have or clients, if they appear with necessary or required updates and for which I do not understand why SCCM does not detect that the customers need such updates.
To provide some more information, I have my laboratory set up under Windows Server 2019 data Center as well as the SQL database and all of it virtualized in Hyper-V and with PKI infrastructure.
I can deploy applications, operating systems, etc, but the patches of Windows 10, I do not get it.
If someone has or has had this same problem, please give me some light or help.
Thank you
Hi @TecnicoOne,
What Win10 build are you running on your client machines? I would expect to discover that many of the build/architecture updates do have 0 required (x86, ARM, older OS builds, etc.).
Are your clients scanning for software updates? If so, how often?
Thanks - BH
Hola, [USER = 11081] @TecnicoOne [/ USER]:
¿Qué compilación de Win10 está ejecutando en sus máquinas cliente? Esperaría descubrir que muchas de las actualizaciones de compilación / arquitectura no requieren 0 (x86, ARM, compilaciones de SO más antiguas, etc.).
¿Están sus clientes buscando actualizaciones de software? Si es así, ¿con qué frecuencia?
Gracias - BH
Hi @bhethcote,
Currently I work with Windows 10 PRO 20H2 64x. I have a gpo that indicates the workstations (PKI) (https: //sccm.matrix.local: 8531). They are scheduled to look for updates every day at 00:00.
I can't find required updates for Windows 10 PRO x64.
Hi @TecnicoOne,
Thanks - BH
Hi @TecnicoOne,
Thanks - BH
Hi @bhethcote,
Hi @TecnicoOne,
What are your client settings for Software Updates? (These settings are from my lab)
If you're using a GPO, I'd be interested to see what the SCCM/MECM client settings are.
Thanks - BH
Hi @TecnicoOne,
Thanks - BH
Hi friend,
This is the configuration of my custom client and my gpo for wsus.
nhamilton
