SOLVED Office 2016 Unmatched exit code is considered an execution failure
CrimsonGhost
I have followed the guide provided to deploy office 2016 in sccm 2012 r2. However it is failing. Here is a copy of my log. Any help would be greatly appreciated.
A user is logged on to the system. AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Performing detection of app deployment type Microsoft Office Professional Plus 2016 - Windows Installer (*.msi file)(ScopeId_B0C71354-B90C-4DF8-AE68-066844470569/DeploymentType_937527f8-ff6b-4c21-ae84-eefcb3608dfc, revision 3) for system. AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
+++ MSI application not discovered [MSI Product Code: {90160000-0011-0000-0000-0000000FF1CE}, MSI Product version: ] AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
App enforcement environment:
Context: Machine
Command line: setup.exe
Allow user interaction: No
UI mode: 0
User token: null
Session Id: 4294967295
Content path: C:\WINDOWS\ccmcache\13
Working directory: AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Prepared working directory: C:\WINDOWS\ccmcache\13 AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Prepared command line: "C:\WINDOWS\ccmcache\13\setup.exe" AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Executing Command line: "C:\WINDOWS\ccmcache\13\setup.exe" with system context AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Working directory C:\WINDOWS\ccmcache\13 AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Post install behavior is BasedOnExitCode AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Waiting for process 9640 to finish. Timeout = 120 minutes. AppEnforce 9/23/2016 8:59:53 AM 9568 (0x2560)
Process 9640 terminated with exitcode: 30066 AppEnforce 9/23/2016 9:00:10 AM 9568 (0x2560)
Looking for exit code 30066 in exit codes table... AppEnforce 9/23/2016 9:00:10 AM 9568 (0x2560)
Unmatched exit code (30066) is considered an execution failure. AppEnforce 9/23/2016 9:00:10 AM 9568 (0x2560)
++++++ App enforcement completed (16 seconds) for App DT "Microsoft Office Professional Plus 2016 - Windows Installer (*.msi file)" [ScopeId_B0C71354-B90C-4DF8-AE68-066844470569/DeploymentType_937527f8-ff6b-4c21-ae84-eefcb3608dfc], Revision: 3, User SID: ] ++++++ AppEnforce 9/23/2016 9:00:10 AM 9568 (0x2560)
Unmatched exit code (30066) is considered an execution failure - Error 30066 comes up when the office installation files are corrupt. Could you delete the app and download the fresh copy and try ?.
daxxi
