NEW Issue with SCCM client installation over VPN
rkg
Hi guys, recently i deploy a SCCM 2107, all is working fine except the client installation with machines over VPN, basically psuh not working from the Server:
  • firewall allow comunication bettwen server and machines over VPN
  • SCCM is working with HTTPS only communication
  • Running the ccmsetup.exe from the share on the server locally on the machine not working.
  • Push from the server not working
The devices working ober VPN are around 140, machines connected to internal doesn´t have issues, cliente is installed, only issue is with clients over VPN.
I tried several things, change comunication Http or Https, run over Powershell locally, run over CMD, download the ccmsetup.exe and run from a local folder in the machine, run from the server share and nothing
Merry Christmas, I will appreciate any help
Attached is the log from the machine on VPN, i just change the name of the server and the domain.
Finally i solved my issue, basically i create a new boundarie group and added all the boundaries discovered, and assign the SCCM site to that new boundarie group. that solved my issue with the clients over VPN and also with local clients that i was facing issues with the push, this was the error that guide me to resolve the issue:
"Failed to get DP locations as the expected version from MP Error 0x87d00215" https://infrontconsulting.asia/sccm...he-expected-version-from-mp-error-0x87d00215/
josed
