SOLVED How to rename intune Co-managed devices?
raghavsood19
1. What are the ways to rename co-managed devices?
- I checked in Intune Rename device option is greyed out.
2. I moved the devices from a co-managed state to Intune the device rename option comes up but when we rename the device it shows a trust relationship issue.
Any suggestions
I had raised a ticket with Microsoft but still, this thing is in progress from their side.
They don't have any solution for this at this point.
Possible solutions:
- Machine can be renamed using PowerShell script when pushed using Task Sequence.
Few things I noticed:
- After the machine migrated from Co-managed to Intune Only, I renamed the machines using Intune configuration policy but for 5/6 machines got renamed perfectly without any issue. Its been 2 weeks no issue reported so far.
For the 6th machine, it got renamed but after 2 days machine moved out of OU and showed an untrusted relationship error. Then to fix the issue we had to join it back to AD using the admin password.
Possible solutions:
If you get a final solution from Microsoft, please update it here. I will leave this thread open for now.
maurie
