PENDING Client install issue
araimondi
HI guys
I was just looking at all my clients under devices and noticed i have about 200 of the 3700 report with no client no status but it has the site code . I tried to reinstall using push method and set the column to say what the last error was and it came back with a 53 . Has any one seen this before? These machines are still in AD
Hi araimondi,
Your MP is published correctly on your DNS? If you try with the manual client installation from your SCCM console, it's worked?
The communication on your MP is setting with HTTPS?
Hi youssef
Yes the MP is published correctly and set to http
That’s the funny thing if I try doing manual client push from console I was able to get a couple to install the client
In your Client Push Installation Propreties, do you have specified an account that has administrator privileges on your clients?
The firewall is disabled on these 200 clients? Can you check in one client if any logs are available (%windir%\ccmsetup\logs) ?
chew
