SOLVED What is the difference between compliant and successfully installed Updates
syed sameer
Hi Prajwal
how are you ?
I want to know what is the difference between compliant and successfully installed updates
as my knowledge once update installed successfully in client machine it becomes compliant, right ?
but if I see compliant PC's there is no updates has installed, kindly guide me
Successfully Installed Updates - When you see this it means that the script have run successfully, and the patch is installed.
You would notice that the status becomes "Compliant" after the update agent processes/verifies the state of the update.
emaria
