SOLVED Problems upgrading Win11 23H2 --> 25H2 PCs using SCCM OSD
  • Thread starter Thread starter SirTimbit
  • Replies Replies 7
  • Views Views 8K
SirTimbit
Hi there! Just curious if others are experiencing the same problems I have in trying to upgrade client PCs from Win11 23H2 to 25H2.
Most of our staff PCs are currently on Win11 Enterprise 23H2, and I'm trying to use an SCCM OSD Upgrade TS to get them up to 25H2. We're currently running ConfigMgr 2509.
It feels like my success rate is half! The machines are all pretty much the same and I don't think it's a problem with the package, given that clearly a good portion of the PCs are upgrading OK.
The client PCs will receive the upgrade TS and start upgrading. From what I've seen, the upgrade fails during the offline portion. I downloaded SetupDiag from Microsoft and the errors are typically:
Error: SetupDiag reports rollback failure found.
Last Phase = Safe OS
Last Operation = Offline portion of machine-specific and machine-independent apply operations
Error = 0x8007042B-0x2000D
Then Windows Setup reverts back to 23H2. As for SCCM itself, Software Center will show the 25H2 upgrade as successful, just to annoy me.
Various steps I've tried include running Cleanmgr, DISM /online /cleanup-image /checkhealth, chkdsk c: /scan, sfc /scannow, windows update reset steps, ensuring our third party AV/EDR software is disabled.
Sometimes this works, but more often than not it seems it doesn't.
I've been Googling away at this for a while and it sounds like others have experienced problems going from 23H2 to 25H2 specifically. See https://techcommunity.microsoft.com...pgrade-fails-in-safe-os--migrate-data/4475743
Now the kicker: what I'm finding a bit odd here is that, if I mount the 25H2 ISO and do a manual upgrade from 23H2 to 25H2, the upgrade completes OK. But this takes longer and requires more manual steps than just kicking off a TS.
The link above suggests Microsoft devs are aware that this may be an issue for 23H2 to 25H2 upgrades but don't have a fix. I haven't found a whole lot of other info on this. I know we used SCCM upgrade TSs to upgrade our fleet of PCs from Win10 to Win11 23H2 a few years ago without much of a problem. We skipped 24H2 as 23H2 was still getting support. With support for 23H2 Enterprise ending this fall however, we've started the upgrades again, only to find it going not so smooth as our previous attempts.
So I'm just trying to get a sense of what others are experiencing in this scenario, or whatever troubleshooting steps I can try. Thanks in advance!
Error: SetupDiag reports rollback failure...
I've been Googling away at this for a while and it sounds like others have experienced problems going from 23H2 to 25H2 specifically. See https://techcommunity.microsoft.com/discussions/windows11/windows-11-23h2-→-25h2-in-place-upgrade-fails-in-safe-os--migrate-data/4475743
Hi SirTimbit
I don't have a solution for your problem. We do it different:
- We go with the "FeatureUpgrade" as an Update.
- As a starter, we deploy the FeatureUpgrade "Windows 11, version 25H2 x64 2026-02" witch is found in the Windows Servicing tab, manually available to all clients.
- Most of our people install the FeatureUpgrade within a couple of weeks. We did the same from W11 22H2 to W11 23H2 with success.
- We have some clients with error, about 1% to 3% of the clients. For those we have either a TaskSequence, that makes an inlineupgrade with a package containing the files from the iso. Or our SupportTeam does the Upgrade manually with the iso from a share.
- The last handfull of clients, that did not start the FeatureUpgrade manually, we deploy it required.
A little bit more work, but it goes well for us.
Maybe our ideas might help you.
khluz
Hi SirTimbit
khluz
Hi khluz, thanks for that suggestion. I will look into that as an option.
Potential solution found... still to test, but wanted to share. My upgrade task sequence was using Windows 11 25H2 media from December 2025. But our Win11 23H2 PCs already have the March cumulative update installed. It's possible that the Setup process is getting confused by finding existing files that are newer than what's provided in the upgrade TS. In short, I will have to slipstream the latest updates into the 25H2 ISO. I will test and let everyone know. But when we uninstalled the most recent cumulative update, the TS upgraded the PC from 23H2 to 25H2 no problem!
Hi SirTimbit
khluz
Hi again khluz,
That method worked for me as well, using the Windows 11, version 25H2 x64 2026-03 update. The upgrade process felt quite a bit longer--about 1.5 hours--than a typical upgrade using the upgrade TS. But it worked.
As luck would have it, MS just released updated ISOs today for Win11 Enterprise, so I'm going to update my media in SCCM and see if the upgrade TS works better after that.
