SOLVED Operating system images in sccm
Hello Prajwal,
Many thanks for your kind support. I have a question which is:
What are the 1-1 and 2-2 Images that are existed in captured and imported Operating Syatem Images in the SCCM. I have added win file of original windows 7 and there is only 1-1, but on the other hand captured Win7 and Win8.1 from virtual machine and found that there are 1-1 and 2-2 images. I forced to disable 1-1 image in the TS as its size is only 17.99 and the installation of windows succeeded. I am attaching a screen shot for the two images I have.
Have I apply both images 1-1 and 2-2? Or I can apply only 2-2 image?
What is the benifit of system reserved?
And If i need to apply both, what will be the TS, what should be applied first and how can be linked with the partitions?
Many Thanks
1-1 partition is used for boot files and recovery info, and is created by default. The second (2-2) partition is the one used for the Windows 7 installation.
If you install from a DVD/Image on to a clean disk, it will create a 100mb partition for you. This will contain all the boot folder and associated files.
mattjimf
