SOLVED How to uninstall Application using SCCM
Hello SCCM Experts,
May i seek for your kind assistance on how to uninstall specific application that is manually installed by the end user? Here is the scenario Employee 1 manually installed Viber application on his/her PC we would like to uninstall it via SCCM.
Thank you.
Yes, also you could test the uninstall command on one of the computer that has the app installed. If the command works fine, then add it to SCCM package.
SWalker
