SOLVED Error configuring BITLOCKER MANAGEMENT web portals
Nano_Magnus
I was trying to config Bitlocker Management on SCCM, I already created de Bitlocker Policy, and after using the .\MBAMWebSiteInstaller.ps1 there is an error
If any one could help me to solve this please
Refressing existing web application HelpDesk
Set-WebConfigurationProperty : Filename: \\?\C:\inetpub\Microsoft BitLocker Management Solution\Help Desk
Website\web.config
Line number: 66
Error: Configuration file is not well-formed XML
At E:\Program Files\Microsoft Configuration Manager\bin\X64\mbamwebsiteinstaller.ps1:1144 char:5
+ Set-WebConfigurationProperty -Filter "/system.webServer/security/ ...
+ CategoryInfo : NotSpecified: (:) [Set-WebConfigurationProperty], COMException
+ FullyQualifiedErrorId : System.Runtime.InteropServices.COMException,Microsoft.IIs.PowerShell.Provider.SetConfigu
rationPropertyCommand
Add-MBAMWebApplication : Failed to disable anonymous autho on web app HelpDesk
At E:\Program Files\Microsoft Configuration Manager\bin\X64\mbamwebsiteinstaller.ps1:1468 char:20
+ ... $success = Add-MBAMWebApplication $webDir $appName $IISWebSite
+ CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,Add-MBAMWebApplication
Sorry, I just found the problem, I made a mistake when I was running the powershell script: .\MBAMWebSiteInstaller.ps1 -SqlServerName sql.contoso.com -SqlInstanceName instance1 -SqlDatabaseName CM_ABC -ReportWebServiceUrl https://rsp.contoso.com/ReportServer -HelpdeskUsersGroupName "contoso\BitLocker help desk users" -HelpdeskAdminsGroupName "contoso\BitLocker help desk admins" -MbamReportUsersGroupName "contoso\BitLocker report users" -SiteInstall Both
I just missed sme letters when I replaced my server and domain on the example script
You could close this tread if you want, it was my mistake and not an error on the configuration process
Sorry
Sorry
lynnc
