NEW Win 10 OS's deployed using SCCM 1910 don't join to AD
ITGuy007
I have created a Task Sequence within SCCM v. 1910 to deploy Windows 10 operating systems.
This task sequence also includes the domain name and Server 2016 domain administrator account to join the operating systems to the Active Directory domain. I have tested that the password I have entered for the domain administrator account is correct by clicking the Test connection button. I then get a message that says "The connection was successfully verified."
However, one thing I have noticed is that after I have tested the connection when I go back into the account setting and test the connection again (using the password that has been previously saved, I get a message that says "The user name or password is incorrect." So it appears that the domain administrator password might not be successfully saved.
The Windows 10 operating systems successfully install on the client computers using this task sequence.
The problem is that once the Windows 10 operating systems have installed I am then unable to logon to them using either a domain account or local user account.
What do I need to do to fix this so that I will be able to logon to these Windows 10 operating systems using either a local or domain user account once they have been loaded using this SCCM version 1910 task sequence?
I need to ensure that the Windows 10 operating systems deployed using this task sequence will either:
1. Successfully attach to the Active Directory domain so I can the logon to them with a domain account
or
2. Create a local account on the Windows 10 OS so I can then logon with this local logon account and join the computer to the domain
dkforeman
