P
pede
Guest
i´m creating Applications via Powershell and i got nearly everything i need, except that for some Apps like Dell Server Admin i need to set a returncode from 3010 - Soft Reboot to Success (no reboot).
I manage Servers, no clients. I want to push it out controlled on a bunch of servers and the reboot can be done on the next Windows Patchday (to reduce number of reboots)
At some points it was caused by a vcredist integrated in the msi.
In order to get no reboot i want to force 3010 to success, which works via the GUI. But in terms of automating i was wondering if there is a way to set that property for this application(not generally for all)
Any Ideas?
Any Ideas?
Code:
$Name = "Dell EMC OpenManage Systems Management Software (64-Bit)-9.5"
$Description = "Windows Server 2012 R2, Windows Server 2019 LTSC, Windows Server 2016"
$Publisher = "Dell"
$SoftwareVersion = "9.5"
$IconLocationFile ="\\SERVERNAME\Sources$\Dell\ServerAdmin\OM.ico"
$MSIFile = "\\SERVERNAME\Sources$\Software\Dell\ServerAdmin\9.5\SysMgmtx64.msi"
$InstallCommand = 'msiexec /i "SysMgmtx64.msi" /l*v c:\windows\temp\Dell-SA.log /q /norestart TRANSFORMS=1033.mst REBOOT=REALLYSUPPRESS'
New-CMApplication -Name $Name -Description $Description -Publisher $Publisher -AutoInstall $true -SoftwareVersion $SoftwareVersion -IconLocationFile $IconLocationFile -DefaultLanguageId 1033
# Create MSI Deployment Type
#OS RULE
$GC = Get-CMGlobalCondition -Name ”Operating System” | Where-Object PlatformType -eq 1
$OS1=Get-CMConfigurationPlatform "All Windows Server 2012 R2 (64-bit)"
$OS2=Get-CMConfigurationPlatform "All Windows Server 2016 (64-bit)"
$OS3=Get-CMConfigurationPlatform "All Windows Server 2019 and higher (64-bit)"
$Rule = $GC | New-CMRequirementRuleOperatingSystemValue -RuleOperator OneOf -Platform $OS1,$OS2,$OS3
Add-CMMsiDeploymentType -ApplicationName $Name -DeploymentTypeName "Install $Name" -ContentLocation $MSIFile -LogonRequirementType WhetherOrNotUserLoggedOn -InstallCommand $InstallCommand -RebootBehavior NoAction -Force -AddRequirement $Rule
