PENDING Unable to connect to remote machine "Client2.Lab.com" using Kerberos with alternate account, error
cfloyd
I've seen only 1 posting here about this, and the person said they fixed it because their DNS server had changed IP's. However this isn' t my issue. I'm doing a Udemy course to better understand and learn MECM as I'm taking over a project for creating and maintaining it as the site I'm working at will be the Enterprise for this project. However, my experince in controlling and maintining MECM is much more limited as previous Enterprise locations wouldn't allow use much ability on it. We could add objects and delete them. That's it. However, I'm going through the training and I was able to push the client to my Domain and the MECM server, however the Client did not receive it. Reperformed the steps... still no go. I created a whole new Client and let MECM autodetect it, as the instructor stated MECM will install the client automatically then. MECM discovered the VM, but still didn't install. I have been able to verify the VM is in AD, I can't remote into the Client from MECM and Domain server, I can ping the Client vm remotely by name, I did the test on MECM to ensure it can access a folder on that client remotely (under Administration when I set up the Boundaries), turned off the firewall on the client and MECM server. I am at my wits end on why the clients are not getting the Client pushed to them. Here is the error logs:
---> The 'best-shot' account has now succeeded 32 times and failed 0 times. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.080+420><thread=7584 (0x1DA0)>
---> Connected to administrative share on machine Client2.Lab.com using account 'LAB\Administrator'~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.080+420><thread=7584 (0x1DA0)>
---> Trying the 'best-shot' account which worked for previous CCRs (index = 0x0)~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.081+420><thread=7584 (0x1DA0)>
---> Attempting to make IPC connection to share <\\Client2.Lab.com\IPC$> with Kerberos authentication ~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.082+420><thread=7584 (0x1DA0)>
---> SspiEncodeStringsAsAuthIdentity succeeded for IPC$ authentication!~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.083+420><thread=7584 (0x1DA0)>
---> SspiExcludePackage succeeded for IPC$ authentication!~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.083+420><thread=7584 (0x1DA0)>
---> SspiMarshalAuthIdentity succeeded for IPC$ authentication!~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.083+420><thread=7584 (0x1DA0)>
---> NetUseAdd succeeded for IPC$ authentication!~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.090+420><thread=7584 (0x1DA0)>
---> Searching for SMSClientInstall.* under '\\Client2.Lab.com\admin$\'~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.090+420><thread=7584 (0x1DA0)>
---> Unable to connect to remote machine "Client2.Lab.com" using Kerberos with alternate account, error - 0x80070005. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.102+420><thread=7584 (0x1DA0)>
--> NTLM fallback is enabled, remote machine "Client2.Lab.com" is continuing with client push. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.103+420><thread=7584 (0x1DA0)>
---> Unable to connect to WMI on remote machine "Client2.Lab.com", error = 0x80070005. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.113+420><thread=7584 (0x1DA0)>
---> Unable to connect to remote machine "CLIENT2" using Kerberos with machine account, error - 0x80070005. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.116+420><thread=7584 (0x1DA0)>
--> NTLM fallback is enabled, remote machine "CLIENT2" is continuing with client push. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.117+420><thread=7584 (0x1DA0)>
---> Unable to connect to WMI on remote machine "CLIENT2", error = 0x80070005. $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.119+420><thread=7584 (0x1DA0)>
---> Deleting SMS Client Install Lock File '\\Client2.Lab.com\admin$\SMSClientInstall.PS1'~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.119+420><thread=7584 (0x1DA0)>
Execute query exec [sp_CP_SetLastErrorCode] 2097152004, -2147024891~ $$<SMS_CLIENT_CONFIG_MANAGER><09-05-2024 14:43:26.122+420><thread=7584 (0x1DA0)>
