PENDING Unable to connect to remote machine and namespace "root\ccm" using Kerberos with Alternate account, error - 0x8004100e
jamisonye
SCCM newbie here, I tried to manually push out client on my test computer on my network but getting this error message on my ccm.log. I verified the computer name and IP address are corrected which stated as a fix for one of the user. I verified the firewall on the client machine is configured correctly to allow wmi and file and print sharing. I tested connection using WBEMTest no issue. I do see files copied over but client just will no install. Can someone point me at what I am doing wrong? Much appreciated.
The install of the client is fine. Why do you think it failed? Did you read the logs from the client?
I figured out from another post. I got an error 0x80200010 on ccmsetup.log on the client machine. Which point to https://forums.prajwaldesai.com/thr...-bg-error-context-is-2-error-0x80200010.3712/
And someone point to default gateway issue. Because I am in the sandbox, I don't have valid or pingable default gateway. It failed right away. To resolve my issue, I just enter the domain controller ip address as my default gateway and it start working.
skanaguk
