NEW SUP Advice
  • Thread starter Thread starter harveybham
  • Replies Replies 0
harveybham
Hi All
I am after some advice which is hopefully a easy question to answer.
Here is my setup
SCCM Running 1806
The main Primary Site holds the SUP Role
There are multiple DP spread across the network.
I have been testing SUP with some mixture of results, now as each site has a DP i have added the sites DP in the boundry group for each site and this works well. When i attempt to do software update on some sites it does not work, if i add the Primary site into the boundry group of the site it works as it picks up the SUP role but of course we do not want this.
Should i add the Primary site into the default boundry group into sccm? Also to mention the software package has been distributed out to each sites DP
