Hello!
This is the second month in a row a SQL CU has installed successfully but SCCM reports it is still required. The update is KB5054833 this month. When ran manually it provides a message that all systems are already updated. Installed Updates show the KB# is installed (SQL Server 2019, Browser for SQL 2019, and VSS Writer). The UpdatesStore.log reports it as missing with 2 different ID's ("1d3dfd10-98e1-4ef3-ba51-dd661ca258ed" and "47a30328-7ded-448e-8697-9f63268c079e"). The KB has been installed on 4 other machines in the domain without issue.
Any help would be appreciated!
Edit: Windows update on the server lists that it requires an update (KB4517790) from 2019. I figured, why not so I downloaded it and it gives me the same message as KB5054833 (image below) so it seems windows update is broken in some manner and this probably isn't a SCCM issue.
