Hey, did you ever figure this out? I have the same issue right now. The last log entry I have is from January 2020 on my primary site server. I think PXE is still working, but it isn't logging anything, and we have a couple of computers that are no PXE booting, but others will. My assumption here is that the tech is using a network dongle that has been previously associated with another computer, and I can usually from this log phish out the mac address of the dongle and add it to the hierarchy as a duplicate hardware id.
Actually my log blew chow back in June of 2019 by the looks of it, here is the last bit of my log.
6/4/2019 9:28:22 AM ================= PXE Provider shutdown. ===================== SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM Failed to shutdown IO completion port. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
The parameter is incorrect. (Error: 80070057; Source: Windows) SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM PXE provided failed to shutdown worker threads. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/4/2019 9:28:22 AM PXE::CPolicyProvider::ShutdownWorkerThreads failed; 0x80070057 SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM Failed to shutdown worker threads. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/4/2019 9:28:22 AM PXE Provider failed to perform a clean shutdown. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/4/2019 9:28:22 AM Prioritizing local MP SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM Not in SSL SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM RequestMPKeyInformation: Send() failed. SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM Unsuccessful in getting MP key information. 80004005. SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM PXE::MP_InitializeTransport failed; 0x80004005 SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM PXE::MP_ReportStatus failed; 0x80070490 SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM PXE::CPolicyProvider::Shutdown failed; 0x80070057 SMSPXE 5728 (0x1660)
6/4/2019 9:28:22 AM Failed to shutdown PXE provider. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/17/2019 11:31:08 AM Cannot read the registry value of MACIgnoreListFile (00000000) SMSPXE 6812 (0x1A9C)
6/17/2019 11:31:09 AM MAC Ignore List Filename in registry is empty SMSPXE 6812 (0x1A9C)
6/17/2019 11:32:31 AM ================= PXE Provider shutdown. ===================== SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM Failed to shutdown IO completion port. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
The parameter is incorrect. (Error: 80070057; Source: Windows) SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM PXE provided failed to shutdown worker threads. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/17/2019 11:32:31 AM PXE::CPolicyProvider::ShutdownWorkerThreads failed; 0x80070057 SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM Failed to shutdown worker threads. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/17/2019 11:32:31 AM PXE Provider failed to perform a clean shutdown. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
6/17/2019 11:32:31 AM Prioritizing local MP . SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM Not in SSL SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM RequestMPKeyInformation: Send() failed. SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM Unsuccessful in getting MP key information. 80004005. SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM PXE::MP_InitializeTransport failed; 0x80004005 SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM PXE::MP_ReportStatus failed; 0x80070490 SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM PXE::CPolicyProvider::Shutdown failed; 0x80070057 SMSPXE 6292 (0x1894)
6/17/2019 11:32:31 AM Failed to shutdown PXE provider. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
1/18/2020 11:55:13 PM Cannot read the registry value of MACIgnoreListFile (00000000) SMSPXE 35592 (0x8B08)
1/18/2020 11:55:13 PM MAC Ignore List Filename in registry is empty SMSPXE 35592 (0x8B08)
1/18/2020 11:58:14 PM ================= PXE Provider shutdown. ===================== SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM Failed to shutdown IO completion port. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
The parameter is incorrect. (Error: 80070057; Source: Windows) SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM PXE provided failed to shutdown worker threads. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
1/18/2020 11:58:14 PM PXE::CPolicyProvider::ShutdownWorkerThreads failed; 0x80070057 SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM Failed to shutdown worker threads. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
1/18/2020 11:58:14 PM PXE Provider failed to perform a clean shutdown. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
1/18/2020 11:58:14 PM Prioritizing local MP. SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM Not in SSL. SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM RequestMPKeyInformation: Send() failed. SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM Unsuccessful in getting MP key information. 80004005. SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM PXE::MP_InitializeTransport failed; 0x80004005 SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM PXE::MP_ReportStatus failed; 0x80070490 SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM PXE::CPolicyProvider::Shutdown failed; 0x80070057 SMSPXE 37360 (0x91F0)
1/18/2020 11:58:14 PM Failed to shutdown PXE provider. This is usually caused by a problem with the program. Please check the Microsoft Knowledge Base to determine if this is a known issue or contact Microsoft Support Services for further assistance.
