PENDING SCCM Remote Distribution Point
Pivax
So, I am having some problems with the remote DP, I have deleted and recreated the site, even gone as far as deleting the VM and building a new server. I configured the required DHCP options on the DHCP scope for testing and that didn't work either, this is now removed. When booting a laptop into PXE, I am getting the following error:
PXE-E16: No offer received
The laptop is getting an IPv4 address as it states the station IP address just above this error. I am able to ping the DP server from the switch (The switch has the DHCP configured onto it). I have configured the DP exactly the same as our other remote DP's, I just cant work out what the issue is and it is driving me mad.
Regards,
Craig
So, managed to get booted to the TS stage, but when we click on a TS to deploy it, it goes through all the dependencies, and then errors with: 0x80070002
Checked and set the network access account to a domain admin account, tested and no difference
Http result: 500 InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
SendResourceRequest() failed. 801901f4 InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
SendResourceRequest(), HRESULT=801901f4 (..\downloadcontent.cpp,612) InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
oDavRequest.GetDirectoryListing (setDirs, setFiles), HRESULT=801901f4 (..\resolvesource.cpp,3072) InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
Download() failed. 801901f4. InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
DownloadContentAndVerifyHash() failed. 80070002. InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
DownloadContentAndVerifyHash ( pszPackageID, L"SMSPackage", saHttpContentSources, saSMBContentSources, saMulticastContentSources, sDestination, dwFlags, L"", 0, dwPackageFlags, mapNetworkAccess ), HRESULT=80070002 (..\resolvesource.cpp,3633) InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
DownloadContentLocally (pszSource, sSourceDirectory, dwFlags, hUserToken, mapNetworkAccess), HRESULT=80070002 (..\resolvesource.cpp,3860) InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
TS::Utility::ResolveSource (pszPkgID, sPath, 0, hUserToken, mapNetworkAccess), HRESULT=80070002 (runcommandline.cpp,406) InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
Failed to resolve the source for SMS PKGID=CIF00025, hr=0x80070002 InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
cmd.Execute(pszPkgID, sProgramName, dwCmdLineExitCode), HRESULT=80070002 (main.cpp,389) InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
Install Software failed to run command line, hr=0x80070002 InstallSoftware 06/02/2019 13:39:27 1044 (0x0414)
Process completed with exit code 2147942402 TSManager 06/02/2019 13:39:27 1940 (0x0794)
!--------------------------------------------------------------------------------------------! TSManager 06/02/2019 13:39:27 1940 (0x0794)
Failed to run the action: Use Toolkit Package.
The system cannot find the file specified. (Error: 80070002; Source: Windows) TSManager 06/02/2019 13:39:27 1940 (0x0794)
MP server http://CIFDC1SCM01 Ports 80,443. CRL=false. TSManager 06/02/2019 13:39:27 1940 (0x0794)
Setting authenticator TSManager 06/02/2019 13:39:27 1940 (0x0794)
Sending StatusMessage TSManager 06/02/2019 13:39:27 1940 (0x0794)
Setting the authenticator. TSManager 06/02/2019 13:39:27 1940 (0x0794)
CLibSMSMessageWinHttpTransport::Send: WinHttpOpenRequest - URL: CIFDC1SCM01:80 CCM_POST /ccm_system/request TSManager 06/02/2019 13:39:27 1940 (0x0794)
Not in SSL TSManager 06/02/2019 13:39:27 1940 (0x0794)
Request was successful. TSManager 06/02/2019 13:39:27 1940 (0x0794)
Set a global environment variable _SMSTSLastActionRetCode=-2147024894 TSManager 06/02/2019 13:39:27 1940 (0x0794)
Set a global environment variable _SMSTSLastActionSucceeded=false TSManager 06/02/2019 13:39:27 1940 (0x0794)
Clear local default environment TSManager 06/02/2019 13:39:27 1940 (0x0794)
Let the parent group (Gather Logs and StateStore on Failure) decides whether to continue execution TSManager 06/02/2019 13:39:27 1940 (0x0794)
The execution of the group (Gather Logs and StateStore on Failure) has failed and the execution has been aborted. An action failed.
Operation aborted (Error: 80004004; Source: Windows) TSManager 06/02/2019 13:39:27 1940 (0x0794)
Failed to run the last action: Use Toolkit Package. Execution of task sequence failed.
Request was successful. TSManager 06/02/2019 13:39:28 1940 (0x0794)
Execution::enExecutionFail != m_eExecutionResult, HRESULT=80004005 (tsmanager.cpp,1273) TSManager 06/02/2019 13:40:18 1940 (0x0794)
Task Sequence Engine failed! Code: enExecutionFail TSManager 06/02/2019 13:40:18 1940 (0x0794)
Task sequence execution failed with error code 80004005 TSManager 06/02/2019 13:40:18 1940 (0x0794)
Cleaning Up. TSManager 06/02/2019 13:40:18 1940 (0x0794)
Removing Authenticator TSManager 06/02/2019 13:40:18 1940 (0x0794)
shKey.DeleteValue( c_szRegValue_SecurityToken ), HRESULT=80070002 (..\CcmUtilLib.cpp,2117) TSManager 06/02/2019 13:40:18 1940 (0x0794)
shKey.DeleteValue(sRegValueName.c_str()), HRESULT=80070002 (..\CcmToken.cpp,1153) TSManager 06/02/2019 13:40:18 1940 (0x0794)
Cleaning up task sequence folder TSManager 06/02/2019 13:40:18 1940 (0x0794)
Unable to delete file D:\_SMSTaskSequence\TSEnv.dat (0x80070005). Continuing. TSManager 06/02/2019 13:40:18 1940 (0x0794)
hr, HRESULT=80070091 (..\CcmFile.cpp,1257) TSManager 06/02/2019 13:40:18 1940 (0x0794)
Failed to delete directory 'D:\_SMSTaskSequence' TSManager 06/02/2019 13:40:18 1940 (0x0794)
(dwRet = ::SetNamedSecurityInfoW ((WCHAR*) pszObjectName, objectType, OWNER_SECURITY_INFORMATION, pOwnerSID, NULL, NULL, NULL)) == ERROR_SUCCESS, HRESULT=80070005 (..\utils.cpp,7463) TSManager 06/02/2019 13:40:18 1940 (0x0794)
SetNamedSecurityInfo() failed. TSManager 06/02/2019 13:40:18 1940 (0x0794)
SetObjectOwner() failed. 0x80070005. TSManager 06/02/2019 13:40:18 1940 (0x0794)
SetObjectOwner (szFName, SE_FILE_OBJECT, c_szAdministrators), HRESULT=80070005 (..\utils.cpp,7560) TSManager 06/02/2019 13:40:18 1940 (0x0794)
RemoveFile() failed for D:\_SMSTaskSequence\TSEnv.dat. 0x80070005. TSManager 06/02/2019 13:40:18 1940 (0x0794)
RemoveDirectoryW failed (0x80070091) for D:\_SMSTaskSequence TSManager 06/02/2019 13:40:18 1940 (0x0794)
Deleting volume ID file C:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca ... TSManager 06/02/2019 13:40:18 1940 (0x0794)
DeleteFileW(sVolumeIDFile.c_str()), HRESULT=80070002 (..\resolvesource.cpp,519) TSManager 06/02/2019 13:40:18 1940 (0x0794)
Deleting volume ID file D:\_SMSTSVolumeID.7159644d-f741-45d5-ab29-0ad8aa4771ca ... TSManager 06/02/2019 13:40:18 1940 (0x0794)
Successfully unregistered Task Sequencing Environment COM Interface. TSManager 06/02/2019 13:40:18 1940 (0x0794)
Command line for extension .exe is "%1" %* TSManager 06/02/2019 13:40:18 1940 (0x0794)
Set command line: "X:\sms\bin\x64\TsProgressUI.exe" /Unregister TSManager 06/02/2019 13:40:18 1940 (0x0794)
Executing command line: "X:\sms\bin\x64\TsProgressUI.exe" /Unregister TSManager 06/02/2019 13:40:18 1940 (0x0794)
==========[ TsProgressUI started in process 1052 ]========== TsProgressUI 06/02/2019 13:40:18 1056 (0x0420)
Command line: "X:\sms\bin\x64\TsProgressUI.exe" /Unregister TsProgressUI 06/02/2019 13:40:18 1056 (0x0420)
Unregistering COM classes TsProgressUI 06/02/2019 13:40:18 1056 (0x0420)
Unregistering class objects TsProgressUI 06/02/2019 13:40:18 1056 (0x0420)
Shutdown complete. TsProgressUI 06/02/2019 13:40:18 1056 (0x0420)
Process completed with exit code 0 TSManager 06/02/2019 13:40:18 1940 (0x0794)
Successfully unregistered TS Progress UI. TSManager 06/02/2019 13:40:18 1940 (0x0794)
g_TSManager.Run(), HRESULT=80004005 (tsmanager.cpp,1029) TSManager 06/02/2019 13:40:18 1940 (0x0794)
::RegQueryValueExW(hSubKey, szReg, NULL, NULL, NULL, &dwSize), HRESULT=80070002 (..\utils.cpp,844) TSManager 06/02/2019 13:40:18 1940 (0x0794)
RegQueryValueExW is unsuccessful for Software\Microsoft\SMS\Task Sequence, SMSTSEndProgram TSManager 06/02/2019 13:40:18 1940 (0x0794)
GetTsRegValue() is unsuccessful. 0x80070002. TSManager 06/02/2019 13:40:18 1940 (0x0794)
End program: TSManager 06/02/2019 13:40:18 1940 (0x0794)
Error Task Sequence Manager failed to execute task sequence. Code 0x80004005 TSManager 06/02/2019 13:40:18 1940 (0x0794)
Sending error status message TSManager 06/02/2019 13:40:18 1940 (0x0794)
MP server http://CIFDC1SCM01 Ports 80,443. CRL=false. TSManager 06/02/2019 13:40:18 1940 (0x0794)
Setting authenticator TSManager 06/02/2019 13:40:18 1940 (0x0794)
Sending StatusMessage TSManager 06/02/2019 13:40:19 1940 (0x0794)
Setting the authenticator. TSManager 06/02/2019 13:40:19 1940 (0x0794)
CLibSMSMessageWinHttpTransport::Send: WinHttpOpenRequest - URL: CIFDC1SCM01:80 CCM_POST /ccm_system/request TSManager 06/02/2019 13:40:19 1940 (0x0794)
Not in SSL TSManager 06/02/2019 13:40:19 1940 (0x0794)
Request was successful. TSManager 06/02/2019 13:40:19 1940 (0x0794)
Finalize logging request ignored from process 1936 TSManager 06/02/2019 13:40:19 1940 (0x0794)
Process completed with exit code 2147500037 TSPxe 06/02/2019 13:40:19 1908 (0x0774)
Task Sequence Manager returned code 0x80004005 TSPxe 06/02/2019 13:40:19 1908 (0x0774)
ThreadToResolveAndExecuteTaskSequence returned code 0x00000000 TSPxe 06/02/2019 13:40:19 1572 (0x0624)
ResolveProgressPage::OnWizardNext() TSPxe 06/02/2019 13:40:19 1572 (0x0624)
Activating Finish Page. TSPxe 06/02/2019 13:40:19 1572 (0x0624)
Exiting with return code 0x00000000 TSPxe 06/02/2019 13:40:19 1572 (0x0624)
Execution complete. TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
hMap != 0, HRESULT=80070002 (..\environmentscope.cpp,493) TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
m_pGlobalScope->open(), HRESULT=80070002 (..\environmentlib.cpp,335) TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
this->open(), HRESULT=80070002 (..\environmentlib.cpp,561) TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
::RegQueryValueExW(hSubKey, szReg, NULL, NULL, NULL, &dwSize), HRESULT=80070002 (..\utils.cpp,844) TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
RegQueryValueExW is unsuccessful for Software\Microsoft\SMS\Task Sequence, SMSTSEndProgram TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
GetTsRegValue() is unsuccessful. 0x80070002. TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
End program: TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
Finalizing logging from process 952 TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
Finalizing logs to root of first available drive TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
Successfully finalized logs to D:\SMSTSLog TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
Cleaning up task sequencing logging configuration. TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
TS::Environment::SharedEnvironment.isInitialized() == true, HRESULT=80004005 (..\tslogging.cpp,694) TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
TS environment is not initialized TSBootShell 06/02/2019 13:40:19 1036 (0x040C)
Failed to resolve the source for SMS PKGID=CIF00025 - check if this package is present on DP and redistribute this package and try again.
Have removed all packages and sending them again, checked the distmgmr.log file and found the following errors when they are being distributed to the remote DP:
Failed to configure IIS module, GLE - 1168 SMS_DISTRIBUTION_MANAGER 08/02/2019 12:51:20 3372 (0x0D2C)
ConfigureIISModules failed to configure IIS module SMS_DISTRIBUTION_MANAGER 08/02/2019 12:51:20 3372 (0x0D2C)
Anything to worry about?
All files distrubted again to the DP, same error and failure as before. Not sure why it cant see the files
When I launch IIS on the DP and browse to the relevant site I receive the following error:
HTTP Error 500.21 - Internal Server ErrorHandler "AboMapperCustom-16765" has a bad module "IsapiModule" in its module list
Just installed the CGI, ISAPI Extensions and ISAPI Filters roles under IIS on the DP server. No longer getting the above error. Will test again shortly and see if that allows access to the PKG
You just saved me a LOT of work figuring out this issue! Thanks for posting the fix!
lynnc
