PENDING SCCM PXE Operating System not Found
  • Thread starter Thread starter memihir
  • Replies Replies 4
  • Views Views 5K
memihir
Hi All,
I am setting up new SCCM server with PXE (new to this)
after setting up now i am getting error which says Operating System not found
I tried to run cmtrace on command line and can see 0x80070002 error in the log, searched net and blog here and found below post but that did not help
https://www.prajwaldesai.com/task-sequence-failed-error-code-0x80070002/
I already has service account assigned to it which has full access.
Any help with this would be appreciated.
Regards
Decoding in non ssl mode failed. Checking if decoding was really needed.
Failed to verify a properly formed XML.
Failed to download policy PR12000D-PR10001A-6F6BCC28 (Code 0x80090010).
To me this seems a PXE certificate issue. I suggest you disable PXE on the DP, remove the boot image on DP. Then enable it again and distribute the boot image. Please report back after doing the step above.
ChaseMcFadden
