PENDING SCCM - Client push installation not working
Strahinja JANACEK
Active Member
Hello!
This week I installed a new SCCM, because we moved to a new windows server 2019.
Now I have the following problem:
When I try to push manually the sccm client installation to a device, I does not work. Here you can see a screenshot from the ccm-log:
Now I have tried to run \\clientname\admin$ on the old server, which is working. I tried the same path \\clientname\admin$ on the new server and I cannot access.
What did I forgot to configure? I believe it's some firewall rule or similar? But everything is configured and the users which is used for install is also set on the old server.
Have a nice weekend!
Best regards,
Strahinja
Hi!
This issue has been solved. On network side they had to implement the same rules as we had it for the old SCCM server. Now everything is working fine.
Best regards,
Strahinja
markmumford
