PENDING SCCM client not reflecting in sccm console after exit code 0
  • Thread starter Thread starter Devanand
  • Replies Replies 10
  • Views Views 10K
Devanand
SCCM client not reflecting in sccm console after exit code 0, checked all ports working fine ...need some suggestions
What is your SCCM version? Windows client version?
Make sure that the Heartbeat Discovery is enabled.
SCCM Version 1902 - 5.8790.1007
Client too same heart beat enable already...
For some servers only not reflecting in console
Action Cycles are not loaded(Only 2 cycles came) taking more time ....but ccmsetup showing exit code 0
How are you installing the client? Manual or push installation?
Make sure that the boundaries and boundaries groups are correctly configured.
That's right, share the ClientLocation.log and LocationServices.log files located on the client in "%WINDIR%\CCM\Logs"
But for me issue is with some machines ..after installing manually ..exit code will be 0 ,if i check from console it will not reflect
Team, I Have removed client completly it worked and reflected in console ,from machine performed below steps
c:\windows\ccmsetup\ccmsetup.exe /uninstall wait until ccmsetup disappears in taskmgr - then 2. rd c:\windows\ccm 3. rd c:\windows\ccmcache 4. rd c:\windows\ccmsetup 5. del c:\windows\smscfg.ini 6. del HKLM\software\Microsoft\ccm registry keys 7. del HKLM\software\Microsoft\CCMSETUP registry keys 8. del HKLM\software\Microsoft\SMS\ 9. del HKLM\software\Microsoft\Systemcertificates\SMS\Certificates done
Team, it worked for one client but i follwed same steps mentioned above still issue persists...
showing older site code..instead of CHE its showing CHN ..Mr.Prajiwal & Youssef help me out ..logs attached
MLab
