PENDING SCCM Application Catalog not displaying applications
  • Thread starter Thread starter imz
  • Replies Replies 6
  • Views Views 4K
imz
HI
Good Evening
The available application are not showing in application catalog website you can se the attached image. Available application are showing in Software Center but not in Applications Catalog Site. I am using USER COLLECTION .no application.JPG
Please take one application for a test, go to the Properties of this and check the following option:
What is the version of your SCCM?
In the console, go to Monitoring, System status and check the health of Application Catalog Website and Web Service roles, are they OK?
SCCM Version is 1902
Please check the attached image of site status from monitoring section.wwwww.JPG
That day i tried everything but today when i opened the system after two i was able to see application in Web catalog as you can see in the image. Which thing need to check ? May be there is some option need to change the schedule time or something related to scheduling because i its working perfectly after 1 or 2 days. Please check the attached image.sdfsf.PNG
When you deploy the application to the user collection, you must configure availability "As soon As possible", ensure that you have checked the "Display application on the company portal" option then update the content of the application in your DP's.
I suggest to you to create a new application and test the above steps with it.
prashantrm
