SOLVED sccm 2012 sup not showing all classifications
typeorulez
I have been looking for the answer to this issue for a number of days now, but with no luck. Maybe you can help me out.
We have a SCCM 2012 R2 Config manager infrastructure with one primary site having the role of wsus, sup and dp. Now when I go to the classification tab of SUP component in configure site components (Administration), i see only two classfications: Critical updates and security updates but in WSUS, we have ticked all the classifications like service packs, etc.
So, how do we get all the classifications in the SUP as well?
Any help would be appreciated,
Thanks,
but in WSUS, we have ticked all the classifications like service packs, etc - Can you uncheck them in WSUS and use SUP to configure the classifications ?.
Hi, Even i'm also facing the same issue, SCCM 2012 R2 SP1 CU3 while reconfiguring SUP role the classification not listed. i have tried to uninstall and reinstall WSUS and SUP role but still no luck.
If anyone resolved this issue let me know, much appreciated for your suggestions.
The issue has been resolved, it's due to Classification table are missing from SCCM database, and we have added the table manually and then the classification start shows during the SUP installation.
It may helpful for others
Nairolf
