Destin
Dear Prajwal:
Really appreciate your blog that solved a lot of my issues with SCCM 2012 R2, but i have a question regarding the CU4 updates, i have successfully update SCCM 2012 R2 to CU4, but I found when I was deploying a new installation of windows 8.1 system the SCCM client installed with the new system is still the older version, is it possible to update the CM Client package on sites so that all new windows installation can have the updated CM client installed? or i'll have to install the older version and update the client afterwards?
Sorry for my bad English. Thank you very much and looking forward to your reply.
Have a good day.
Have a good day.
