I have configured 1802 for Wake on LAN with subnet-directed broadcasts.
SCCM has 2 network interfaces (1 in VLAN for servers and 1 in VLAN for provisioning).
We are using provisioning VLAN for OSD.
After OSD all clients are moved to another VLAN.
We have configured our network switches to allow broadcasts for magic packets.
We have tested WOL using a utility from SCCM and clients wake up.
We have used WOLMonitor to monitor if UDP packets are sent from SCCM.
The problem appears when when we are deploying a TS as required and select Send wake-up Packets.
wolcmgr.log file shows that the system is sending packets, but WOLMonitor does not capture any packets and clients do not wake up.
I would kindly request for your help in order to troubleshoot the case.
Thank you in advance.
