NEW PXE Issue in a Distribution Point
Alpha713
Dear all,
would you please have a look at the SMSPXE log as I am currently unable to Boot through PXE after recreating the boot image.
Everything was working fine prior to messing around with the PE Boot Image.
I would highly appreciate if you can get back to me at your earliest.
regards
  • Did you update the correct NIC drivers from the task sequence driver tab?
  • Check if any missing content on the distribution point. (i.e., select task sequence -> references tab -> check all contents are updated.)
  • Select Task sequence -> properties -> ensure you have selected the correct boot image and up to date (including NIC drivers)
  • check EFI or legacy settings in BIOS
If no issues from task sequence, then delete the remoteinstall folder and re-install PXE components.
zehcavalheiro
