PENDING Problem with clients and reinstall SCCM agent
  • Thread starter Thread starter Portu
  • Replies Replies 0
  • Views Views 859
Portu
Good morning,
I am having problems reinstalling some SCCM agents on computers. Some computers stopped connecting to the PS at different points in time, and now I am trying to review them and perform a manual uninstall and a manual reinstall of the agent.
The problem is that the installation of the agent is not done correctly and I have already tried a multitude of things.
I will attach the Log.
I have tried to do the following to uninstall the agent:
Try { Set-ExecutionPolicy -ExecutionPolicy Bypass -Scope Process -Force -ErrorAction Stop } Catch {}
#StopServices
Stop-Service -Name ccmsetup -Force -ErrorAction SilentlyContinue
Stop-Service -Name CcmExec -Force -ErrorAction SilentlyContinue
Stop-Service -Name smstsmgr -Force -ErrorAction SilentlyContinue
Stop-Service -Name CmRcService -Force -ErrorAction SilentlyContinue
# Remove WMI Namespaces
Get-WmiObject -Query "SELECT * FROM __Namespace WHERE Name='ccm'" -Namespace root | Remove-WmiObject
Get-WmiObject -Query "SELECT * FROM __Namespace WHERE Name='sms'" -Namespace root\cimv2 | Remove-WmiObject
# Remove Services from Registry
$MyPath = “HKLM:\SYSTEM\CurrentControlSet\Services”
Remove-Item -Path $MyPath\CCMSetup -Force -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\CcmExec -Force -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\smstsmgr -Force -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\CmRcService -Force -Recurse -ErrorAction SilentlyContinue
# Remove SCCM Client from Registry
$MyPath = “HKLM:\SOFTWARE\Microsoft”
Remove-Item -Path $MyPath\CCM -Force -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\SMS -Force -Recurse -ErrorAction SilentlyContinue
# Remove Folders and Files
$MyPath = $env:WinDir
Remove-Item -Path $MyPath\ccmsetup -Force -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\ccmcache -Force -Recurse -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\SMSCFG.ini -Force -ErrorAction SilentlyContinue
Remove-Item -Path $MyPath\SMS*.mif -Force -ErrorAction SilentlyContinue
And then I reinstall the agent and it always gives me the same error. Is there a cleaner way to uninstall and reinstall? (The push from SCCM does not work because it does not connect)
I don't know what else to try...
Thanks in advance,
All the best,
