PENDING Office Pro Plus 2016 Volume and Visio Pro and Project Pro volume
cmedina
I am having a problem with SCCM and Office. I can deploy Office Pro Plus with no problem. When it come to Project Pro and Visio Pro 2016 we have a problem. I can install just fine but I can't uninstall from software center. We are using current branch 1806 of SCCM. I have tried numerous configuration.xml files and the office deployment tool. I was wondering if someone could help shed some light when we deploy Visio or project separately through software center but I can't uninstall the program. I have so many different error when I make changes I have lost count. Here is the last Appenforce log.
Thanks for the log file. I see all your .msi apps are failing with error "Unmatched exit code (1603) is considered an execution failure". I suggest you to recreate the deployment type by downloading the fresh msi file.
Twc
