NEW Multi app kiosk MS edge inprivate not working
  • Thread starter Thread starter kd3000
  • Replies Replies 1
kd3000
Hi all,
We deployed pc's in multi app kiosk mode (windows 10, trough Intune) and we used the intune kiosk profile with a customized xml for the start menu.
Everything works, only Edge inprivate is an issue. we deployed an Edge configuration (settings catalog) with a specific list of restrictions. we want to autostart Edge in inprivate mode(wat is does) with an homepage url (internal weburl, it does not run). if we disable the inprivate or make it available, everything works, but all the settings are visible for the end user, so all other restrictions are ignored, when we enforce the inprivate mode, everything works... only not the "url for new tab" and not the "homepage" .... we used the intune app deployment (intune - apps- add new- Microsoft Edge, version 77 and later)
i cant imagine that it is not possible, we started all over for the 4th time.. even tried to wrap edge as an win32 app with the same config -> same behavior.
Anyone an idea?
maurie
