PENDING Management Point Issue Internal server error
Hi sir, P
Log file:- Call to HttpSendRequestSync failed for port 80 with status code 500, text: Internal Server Error. Http test request failed, status code is 500, 'Internal Server Error'.Component status:- SMS_MP_CONTROL_MANAGER 5436 MP Control Manager detected management point is not responding to HTTP requests. The HTTP status code and text is 500, Internal Server Error. Possible cause: Management point encountered an error when connecting to SQL Server. Solution: Verify that the SQL Server is properly configured to allow Management Point access. Verify that management point computer account or the Management Point Database Connection Account is a member of Management Point Role (msdbrole_MP) in the SQL Server database.
Possible cause: The SQL Server Service Principal Names (SPNs) are not registered correctly in Active Directory Solution: Ensure SQL Server SPNs are correctly registered. Review Q829868.
Possible cause: Internet Information Services (IIS) isn't configured to listen on the ports over which the site is configured to communicate. Solution: Verify that the designated Web Site is configured to use the same ports which the site is configured to use.
Possible cause: The designated Web Site is disabled in IIS. Solution: Verify that the designated Web Site is enabled, and functioning properly.
Possible cause: The MP ISAPI Application Identity does not have the requisite logon privileges. Solution: Verify that the account that the MP ISAPI is configured to run under has not been denied batch logon rights through group policy.
AS i have gone through this link.
1536313776753-png.1480
I have Checked the above highlighted but i fond only the below one in my server.
<httpCompression directory="%SystemDrive%\inetpub\temp\IIS Temporary Compressed Files">
<scheme name="gzip" dll="%Windir%\system32\inetsrv\gzip.dll" />
<scheme name="xpress" doStaticCompression="false" dll="C:\Windows\system32\inetsrv\suscomp.dll" />
<staticTypes>
Please help me with this. Thanks in Advance.!!
Did you verify the first possible cause ?
Checked everything is fine and now i can see the highlited command in previous msg but still the same issue remains..
ljrb
