PENDING Machine Record in SCCM Devices Problem ( DDR)
  • Thread starter Thread starter Dhanabal M
  • Replies Replies 1
Dhanabal M
Hi Guys,
I have one problem. I have installed SCCM client on 2 of my workgroup computers and successfully got installed and reported into SCCM. I have noticed that SCCM assigning a single same GUID and Resource ID to both machine records in Devices which i found in dataldr.log.
The problem is here, whenever i can see the machine 1 in console Devices section Machine 2 unable to see. then if I login to Machine 2 and enforce DDR policies then i can see Machine 2 in Console Devices, but Machine 1 now got disappeared. it happens vise versa.
to conclude that at the same time i can able to visible only 1 record in Devices. if one come other disappear and understood that SCCM not assigning a new Resource ID and GUID to newly provisioned machines.
Resource ID : 16778012
Begin transaction: Machine=Machine1(GUID:8880ACCA-6ADA-4229-BFDD-98B47FC63C3E)
Begin transaction: Machine=Machine2(GUID:8880ACCA-6ADA-4229-BFDD-98B47FC63C3E)
Please provide your suggestion on this and let me know if anyone experience this issue.
Appears you either [cloned PC-B from PC-A | setup both] with a non-sysprep'ed image.
On one of the clients:
1. Stop the CCMEXEC service.
2. Rename %windir%\SMSCFG.INI
3. Delete the SCCM certs at a command prompt run:
a) certutil –delstore SMS SMS
b) or run CCMDELCERT (I forget which, I think this does the same as A; been a while)
4. Start the CCMEXEC service.
5. Run a Machine Policy Ret & Eval.
prashantrm
