SOLVED Issue with EDGE deployment
  • Thread starter Thread starter Datafast
  • Replies Replies 7
  • Views Views 6K
Datafast
I am trying to deploy EDGE and following your tutorial I have done thhe steps below:
1) create EDGE package application
2) create a collection (included only the test pc)
3) ditribuite to the right DP group ( discovered by IP boundary group)
4) deployed EDGE
Although I see the package present in the content of each DP after 2 days it is not been installed.
What could be the reason....How can I troubleshoot it ?
Did you create an Application or a Package? Have you reviewed the log files?
I have followed this prajwaldesai tutorial
The tutorial suggested me to check in the AppEnforce.log but inside it is not present anything related with EDGE.
I can see the application present in the content of the DP group.
Since you didn't link to the blog and you used BOTH App and Packages within the text, I needed to guess at what you are trying to do.
Did you confirm that the policies have download to execute Edge? Did you check your boundaries? What other troubleshooting have you done?
Those are the only step I did to deploy EDGE:
1) I download the last version of EDGE: https://www.microsoft.com/en-us/edge/business/download
2) I created the application
3) I selected the computers test in the console and create a device collection
4) Based on the IP of the test machine I have found the DP Group linked to it. I have distributed the application to content to all SCCM distribution points gruops.
5) I checked the DPs content I could see EDGE app present in all of them
6) Last step I have deployed EDGE
7) The only troubleshoot I have done was look at the AppEnforce.log.
Inside it is not present note related with EDGE deployment.
I have done all the steps again. This time the edge appeared in the software centre but it wasn't installed automatically.
During the deployment I have shoosed this options:
1) install + required
2) notification: display in software center and display all notifications + system restart.
appdiscovery.log
immagine
