PENDING Issue using PXE boot Configuration Manager is looking for policy
michaelalzipperer0
Active Member
I have been having issues with setting up PXE Boot I have the feature enabled and WDS installed letting PXE Boot install it, I had installed it myself first then enabled PXE Boot before but I was getting the same errors so I Disabled PXE Bood uninstalled WDS and then let SCCM install WDS when I re-enabled PXE Boot after rebooting it.
the Boot Image for both X64 and X86 are Distributed and show up under Content Status as 100% compliant.
on the computer, it shows that it starts to talk to the server and then I get a message that states Message from Administrator: Configuration Manager is looking for policy. then it states its contacting the server then moves to boot to next device.
OK im a bit configued on how to tell my ADK version , so I looked it up and found that looking at my Windows Assessment and Deployment Kit - Windows 10 version will determine that which is 10.1.18362.1 which according to means im 1903 with a Configuration Manager sitting at 1906 , however when I look at my Build and version listing with BG Info it states Version 1607 Build 14393. any idea which is true?
Your log's saying that boot image needs to be updated, instinctively I'd ask if you updated the DP's with the new ADK when you installed it.
  • Like
Reactions: Edy
sorry for this question but I'm basically self teaching myself via videos and a lot of trial and error so im trying to understand your statement, I have updated SCCM sins I first installed it but did not know how to update the Boot images the x64 and x86 from what I understand I should just go to the boot images section right-click on each one and click update distribution point and check of the Reload this boot image with the current Windows PE version from the Windows ADK , is that correct?
ok after doing the steps I got passed the black screen and it started to load Windows PE but then it reboots after about a second and then I get the black screen with configuration manager is looking for policy and then pxe boot aborted booting to next device.
the logs are
============> Received from client: SMSPXE 10/15/2019 11:15:27 AM 7612 (0x1DBC)
Operation: BootRequest (1) Addr type: 1 Addr Len: 6 Hop Count: 0 ID: 253C4EE9
Sec Since Boot: 4 Client IP: 000.000.000.000 Your IP: 000.000.000.000 Server IP: 000.000.000.000 Relay Agent IP: 000.000.000.000
Addr: e4:54:e8:4e:3c:25:
Magic Cookie: 63538263
Options:
Type=53 Msg Type: 1=Discover
Type=55 Param Request List: 0102030405060b0c0d0f10111216171c28292a2b3233363a3b3c42438081828384858687
Type=57 Max Msg Size: 04ec
Type=97 UUID: 0044454c4c590010428051b6c04f465832
Type=93 Client Arch: Intel x86PC
Type=94 UNDI: 010201
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 11:15:27 AM 7612 (0x1DBC)
Getting boot action for unknown machine: item key: 2046820352 SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
Not in SSL. SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
Request using architecture 0. SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
Client boot action reply: <ClientIDReply><Identification Unknown="0" DuplicateSMBIOS="0" DuplicateMACAddress="0" ItemKey="2046820352" ServerName=""><Machine><ClientID/><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="" OfferIDTime="" PkgID="" PackageVersion="" PackagePath="" BootImageID="" Mandatory=""/></ClientIDReply>
Request retry. SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: no advertisements found SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: No boot action. Rejected. SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: Not serviced. SMSPXE 10/15/2019 11:15:27 AM 10036 (0x2734)
============> Received from client: SMSPXE 10/15/2019 11:15:31 AM 7516 (0x1D5C)
Options:
Type=53 Msg Type: 3=Request
Type=50 Requested IP: 192.168.209.004
Type=54 Svr id: 192.168.209.125
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 11:15:31 AM 7516 (0x1D5C)
Sec Since Boot: 4 Client IP: 192.168.209.004 Your IP: 000.000.000.000 Server IP: 000.000.000.000 Relay Agent IP: 000.000.000.000
Options:
============> REQUEST Reply to client ([192.168.209.004:68]) Len:348 SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Operation: BootReply (2) Addr type: 1 Addr Len: 6 Hop Count: 0 ID: 253C4EE9
Sec Since Boot: 4 Client IP: 192.168.209.004 Your IP: 000.000.000.000 Server IP: 192.168.209.007 Relay Agent IP: 000.000.000.000
BootFile: smsboot\x86\wdsnbp.com
Options:
Type=53 Msg Type: 5=Ask
Type=54 Svr id: 192.168.209.007
Type=250 02010105040000000e03020014040200ba062c436f6e66696775726174696f6e204d616e61676572206973206c6f6f6b696e6720666f7220706f6c6963792e0b0101 SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
<============ REQUEST Reply (end) SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Sec Since Boot: 0 Client IP: 192.168.209.004 Your IP: 000.000.000.000 Server IP: 000.000.000.000 Relay Agent IP: 000.000.000.000
Options:
Type=250 0d0208000e01010102000605040000000eff
Type=55 Param Request List: 03013c8081828384858687 SMSPXE 10/15/2019 11:15:31 AM 7516 (0x1D5C)
Getting boot action for unknown machine: item key: 2046820353 SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Not in SSL. SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Request using architecture 9. SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Client boot action reply: <ClientIDReply><Identification Unknown="0" DuplicateSMBIOS="0" DuplicateMACAddress="0" ItemKey="2046820353" ServerName=""><Machine><ClientID/><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="" OfferIDTime="" PkgID="" PackageVersion="" PackagePath="" BootImageID="" Mandatory=""/></ClientIDReply>
Request retry. SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: no advertisements found SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
============> REQUEST Reply to client ([192.168.209.004:68]) Len:280 SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Sec Since Boot: 0 Client IP: 192.168.209.004 Your IP: 000.000.000.000 Server IP: 192.168.209.007 Relay Agent IP: 000.000.000.000
BootFile: smsboot\x64\abortpxe.com
Options:
Type=60 ClassId: PXEClient SMSPXE 10/15/2019 11:15:31 AM 10036 (0x2734)
Completed validation of Certificate [Thumbprint 7B0A679BE7418B90AC2D1FC33E27BA7C7024F5DE] issued to '{4D2A98FD-B770-4FE0-B84C-4D6E595C48D8}' SMSPXE 10/15/2019 11:20:34 AM 23248 (0x5AD0)
I tried rebuilding the task sequence just it was somehow linked to an old version ob the boot image but after I did that now I don't even get the Windows PE screen it just throws back Configuration manager is looking for policy after it starts the Download WDSNBP form the server and marks it as a X64.
============> Received from client: SMSPXE 10/15/2019 12:28:45 PM 4924 (0x133C)
Options:
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 12:28:45 PM 4924 (0x133C)
Getting boot action for unknown machine: item key: 2046820352 SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
Not in SSL. SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
Request using architecture 0. SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
Request retry. SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: no advertisements found SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: No boot action. Rejected. SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: Not serviced. SMSPXE 10/15/2019 12:28:45 PM 6384 (0x18F0)
============> Received from client: SMSPXE 10/15/2019 12:28:49 PM 4932 (0x1344)
Options:
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 12:28:49 PM 4932 (0x1344)
Options:
============> REQUEST Reply to client ([192.168.209.004:68]) Len:348 SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
Options:
Type=250 02010105040000000903020014040200ba062c436f6e66696775726174696f6e204d616e61676572206973206c6f6f6b696e6720666f7220706f6c6963792e0b0101 SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
<============ REQUEST Reply (end) SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
============> Received from client: SMSPXE 10/15/2019 12:28:49 PM 4924 (0x133C)
Options:
Type=250 0d0208000e010101020006050400000009ff
Type=55 Param Request List: 03013c8081828384858687 SMSPXE 10/15/2019 12:28:49 PM 4924 (0x133C)
Getting boot action for unknown machine: item key: 2046820353 SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
Not in SSL. SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
Request using architecture 9. SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
Request retry. SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: no advertisements found SMSPXE 10/15/2019 12:28:49 PM 6384 (0x18F0)
Not in SSL. SMSPXE 10/15/2019 12:28:50 PM 6384 (0x18F0)
============> REQUEST Reply to client ([192.168.209.004:68]) Len:280 SMSPXE 10/15/2019 12:28:50 PM 6384 (0x18F0)
Options:
Type=60 ClassId: PXEClient SMSPXE 10/15/2019 12:28:50 PM 6384 (0x18F0)
<============ REQUEST Reply (end) SMSPXE 10/15/2019 12:28:50 PM 6384 (0x18F0)
I deployed it to the All Unknown Computers default device collection, which had me disable PXE boot and uninstall WDS and Delete the RemoteInstall folder and then after reboot re-enable PXE boot then let it re-install WDS and the boot images
then I switched to a different computer and now getting different logs.
============> Received from client: SMSPXE 10/15/2019 5:36:27 PM 10492 (0x28FC)
Operation: BootRequest (1) Addr type: 1 Addr Len: 6 Hop Count: 0 ID: FFA17F6A
Addr: 64:00:6a:7f:a1:ff:
Options:
Type=97 UUID: 0044454c4c4700104a8037b8c04f4d3832
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 5:36:27 PM 10492 (0x28FC)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
Not in SSL. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
Client lookup reply: <ClientIDReply><Identification Unknown="0" DuplicateSMBIOS="0" DuplicateMACAddress="0" ItemKey="0" ServerName=""><Machine><ClientID/><NetbiosName/></Machine></Identification></ClientIDReply>
64:00:6A:7F:A1:FF, 4C4C4544-0047-4A10-8037-B8C04F4D3832: Device is not in the database. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
Getting boot action for unknown machine: item key: 2046820352 SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
Request using architecture 0. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
Request retry. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
64:00:6A:7F:A1:FF, 4C4C4544-0047-4A10-8037-B8C04F4D3832: no advertisements found SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
64:00:6A:7F:A1:FF, 4C4C4544-0047-4A10-8037-B8C04F4D3832: No boot action. Rejected. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
64:00:6A:7F:A1:FF, 4C4C4544-0047-4A10-8037-B8C04F4D3832: Not serviced. SMSPXE 10/15/2019 5:36:27 PM 14268 (0x37BC)
============> Received from client: SMSPXE 10/15/2019 5:36:31 PM 18992 (0x4A30)
Options:
Type=50 Requested IP: 192.168.209.014
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 5:36:31 PM 18992 (0x4A30)
Sec Since Boot: 4 Client IP: 192.168.209.014 Your IP: 000.000.000.000 Server IP: 000.000.000.000 Relay Agent IP: 000.000.000.000
Options:
============> REQUEST Reply to client ([192.168.209.014:68]) Len:348 SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Operation: BootReply (2) Addr type: 1 Addr Len: 6 Hop Count: 0 ID: FFA17F6A
Sec Since Boot: 4 Client IP: 192.168.209.014 Your IP: 000.000.000.000 Server IP: 192.168.209.007 Relay Agent IP: 000.000.000.000
Options:
Type=250 02010105040000000803020014040200ba062c436f6e66696775726174696f6e204d616e61676572206973206c6f6f6b696e6720666f7220706f6c6963792e0b0101 SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
<============ REQUEST Reply (end) SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Sec Since Boot: 0 Client IP: 192.168.209.014 Your IP: 000.000.000.000 Server IP: 000.000.000.000 Relay Agent IP: 000.000.000.000
Options:
Type=250 0d0208000e010101020006050400000008ff
Type=55 Param Request List: 03013c8081828384858687 SMSPXE 10/15/2019 5:36:31 PM 18992 (0x4A30)
Getting boot action for unknown machine: item key: 2046820353 SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Not in SSL. SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Request using architecture 9. SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Request retry. SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
64:00:6A:7F:A1:FF, 4C4C4544-0047-4A10-8037-B8C04F4D3832: no advertisements found SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
============> REQUEST Reply to client ([192.168.209.014:68]) Len:280 SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Sec Since Boot: 0 Client IP: 192.168.209.014 Your IP: 000.000.000.000 Server IP: 192.168.209.007 Relay Agent IP: 000.000.000.000
Options:
Type=60 ClassId: PXEClient SMSPXE 10/15/2019 5:36:31 PM 14268 (0x37BC)
Begin validation of Certificate [Thumbprint 7B0A679BE7418B90AC2D1FC33E27BA7C7024F5DE] issued to '{4D2A98FD-B770-4FE0-B84C-4D6E595C48D8}' SMSPXE 10/15/2019 5:37:16 PM 21792 (0x5520)
Completed validation of Certificate [Thumbprint 7B0A679BE7418B90AC2D1FC33E27BA7C7024F5DE] issued to '{4D2A98FD-B770-4FE0-B84C-4D6E595C48D8}' SMSPXE 10/15/2019 5:37:16 PM 21792 (0x5520)
the first computer is still giving me the same issue with logs below
============> Received from client: SMSPXE 10/15/2019 5:46:50 PM 18868 (0x49B4)
Options:
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 5:46:50 PM 18868 (0x49B4)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
Not in SSL. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: Device is not in the database. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
Getting boot action for unknown machine: item key: 2046820352 SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
Request using architecture 0. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
Request retry. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: no advertisements found SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: No boot action. Rejected. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: Not serviced. SMSPXE 10/15/2019 5:46:50 PM 14268 (0x37BC)
============> Received from client: SMSPXE 10/15/2019 5:46:54 PM 18868 (0x49B4)
Options:
Type=60 ClassId: PXEClient:Arch:00000:UNDI:002001 SMSPXE 10/15/2019 5:46:54 PM 18868 (0x49B4)
Options:
============> REQUEST Reply to client ([192.168.209.004:68]) Len:348 SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Options:
Type=250 02010105040000000903020014040200ba062c436f6e66696775726174696f6e204d616e61676572206973206c6f6f6b696e6720666f7220706f6c6963792e0b0101 SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
<============ REQUEST Reply (end) SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Options:
Type=55 Param Request List: 03013c8081828384858687 SMSPXE 10/15/2019 5:46:54 PM 18868 (0x49B4)
Getting boot action for unknown machine: item key: 2046820353 SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Prioritizing local MP http://STOH007.stoh.local. SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Not in SSL. SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Request using architecture 9. SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Request retry. SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
E4:54:E8:4E:3C:25, 4C4C4544-0059-4210-8051-B6C04F465832: no advertisements found SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
============> REQUEST Reply to client ([192.168.209.004:68]) Len:280 SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
Options:
Type=60 ClassId: PXEClient SMSPXE 10/15/2019 5:46:54 PM 14268 (0x37BC)
i kept reading SSL. is secure boot enabled? also on the Distribution Point role properties setting, is the option "Enable unknown computer support" selected?
Enable unknown computers is selected, I dont believe secure boot is enabled can you tell me where to check that in SCCM so I can make shure and I'll check it asap.
Oye chico! The site has a nice function to attach text files to posts rather than dumping 30 paragraphs to the page. :)
Now that you're past the whole non-updated ADK issue, ensure:
Basic DHCP is setup.
The PXE options are setup in DHCP.
Your CM site is configured to use PXE.
The last boot image you updated to the DP is the one you want to serve via PXE.
The TS you want to serve is set as Available, deployed to Unknown Comupters, and scheduled to start at a time +12h in the past.
The target system has no existing device object in CM.
The target system is booting in a manner compatible with what the TS is expecting.
I saw this in your last post:
I hate this "error". Been seeing it occur as a result of not configuring CM in a way that's not documented well.
the only thing I have not checked off on your list is the +12Hr sins it won't let me put a time before I deployed it so I need to wait every time I rebuild the task and I rebuilt the task yesterday afternoon.
"+12h in the past." is to say "greater than 12 hours in the past" so that 's been more than 12 hours since the time for it to become available.
Rebuild the deployment, for scheduling reduce the day -1 and increase the hour +1, that will make it be available as of 23 hours ago. You won't have to wait 23 hours, it should be available immediately, which is what you'd think "as soon as possible" does but...
Don't think it was ever asked... are you setting the option for "Make available to the following" to something with PXE in it for the deployment options?
DailyLlama
