PENDING Issue using PXE boot Configuration Manager is looking for policy
michaelalzipperer0
Active Member
I have been having issues with setting up PXE Boot I have the feature enabled and WDS installed letting PXE Boot install it, I had installed it myself first then enabled PXE Boot before but I was getting the same errors so I Disabled PXE Bood uninstalled WDS and then let SCCM install WDS when I re-enabled PXE Boot after rebooting it.
the Boot Image for both X64 and X86 are Distributed and show up under Content Status as 100% compliant.
on the computer, it shows that it starts to talk to the server and then I get a message that states Message from Administrator: Configuration Manager is looking for policy. then it states its contacting the server then moves to boot to next device.
Check that your boot image is being deployed:
Software Library>Operating Systems>Boot Images>MyBootImage... Properties>Data Source>"Deploy this boot image from the PXE-enabled distribution point"
Also check that unknown computers are being deployed a task sequence.
When you deployed the TS did you:
Set "Make available to the following" to an item that included PXE?
Set the scheduling availibility to 12 - 23 hours in the past and not use "as soon as possible"?
the first part yes I did have it set to ASAP but changed it to the same time as become available, I can't put it before then because it won't let me and I cant set the scheduled time before the time im creating it.
Delete and redeploy, on the scheduling set availible to D-1, H+1.
I never had WDS installed, I notice on your first screen shot the checkbox for "Enable a PXE responder without Windows Deployment Services" is still enabled (though not checked) which gives me the impression SCCM still thinks it's there and a reboot may be required.
Did a reboot and still same issue, that checkbox is to Enable PXE to respond without using Windows Deployment I leave that unchecked sins from what I understand that is for if I want to try to use PXE boot without having WDS at all. I have not tried that sins every documentation I have looked at so far states that WDS is used and no one ever checks that of.
your client and server on different vlans or you just have a big subnet? you would need ip helper set up if they are on different subnets.
According to the information that I was reading you are supposed to set up 066 and 067 options in the DHCP server, all the information I found on IP Helper was if It failed to find the SCCM server however as you see in the logs they both see each other and are communicating. did I read incorrectly?
ok, thats how i knew to get pxe boot working if client and servers on different vlans.
have you assigned boot image to your TS?
probably try changing your TS from required to available to all unknown computers
just delete the deployment and redeploy to all unknown computers with available purpose
chew
