PENDING installing SCCM distribution point
  • Thread starter Thread starter dj3094
dj3094
Hello all,
what all parameters we need to consider before installing distribution point.
Regards
DJ
You need a supported Windows Server OS and install few prerequisites and you are good to install the DP role. You must also ensure you have an additional drive for storing the content because the clients download the content from DP.
Thanks Prajwal, Sorry I posted question wrong, what I meant to ask is lets say if there is a remote site what things to be considered to install a dp or pull dp and also bandwodth requirements
How many users are there in the remote site ?. If there are just few users, you could point to main DP provided the bandwidth is good and avoid setting up local DP. If there are many users (50+) setting up a local DP makes sense.
Now coming to configuring the Pull DP, you can allow the new DP to download the content from nearest available DP instead of downloading the content from main DP. For more info refer this post - https://www.prajwaldesai.com/sccm-pull-distribution-point-settings/
