Hi Sir,
can i upgraded with win 10 1903 in dell optiplex 380,390 desktop.
Please find the below setupact.log .
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: DpxUnload
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: SrUnload
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: CbsEsdUnload
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: CbsTraceInfoUninitialize
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: CbsEventUnregister
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: AppContainerUnload
2019-11-04 12:17:30, Info CBS CbsCoreFinalize: WdsUnload, logging from cbscore will end.
2019-11-04 12:17:30, Info DISM DISM Provider Store: PID=1576 TID=1600 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:30, Info DISM DISM Provider Store: PID=1576 TID=1600 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:30, Info DISM DISM Provider Store: PID=1576 TID=1600 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM DISM OS Provider: PID=1576 TID=1600 Successfully unloaded all registry hives. - CDISMOSServiceManager::Final_OnDisconnect
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1576 TID=1600 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM DISM Manager: PID=1020 TID=1572 Closing session event handle 0x10e8 - CDISMManager::CleanupImageSessionEntry
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1020 TID=1572 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1020 TID=1572 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1020 TID=1572 Disconnecting Provider: WimManager - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1020 TID=1572 Disconnecting Provider: VHDManager - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1020 TID=1572 Disconnecting Provider: GenericImagingManager - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM DISM Provider Store: PID=1020 TID=1572 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=1572 Leave CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Leave DismCloseSessionInternal - DismCloseSessionInternal
2019-11-04 12:17:31, Info MIG OC::COCDismAdapter::Release: DISM session closed succeessfully
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Enter DismShutdownInternal - DismShutdownInternal
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 GetReferenceCount hr: 0x0 - CSessionTable::RemoveSession
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Refcount for DismSession= 1s 0 - CSessionTable::RemoveSession
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=1568 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=1568 Successfully dequeued command object - CCommandThread:
equeueCommandObject
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=1568 ExecuteLoop: Cancel signaled - CCommandThread::ExecuteLoop
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=1568 Leave CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=1568 Leave CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Deleted g_internalDismSession - DismShutdownInternal
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Shutdown SessionTable - DismShutdownInternal
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 Leave DismShutdownInternal - DismShutdownInternal
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 DismApi.dll: - DismShutdownInternal
2019-11-04 12:17:31, Info DISM API: PID=1020 TID=284 DismApi.dll: <----- Ending DismApi.dll session -----> - DismShutdownInternal
2019-11-04 12:17:31, Info MIG DismShutdown hr = 0x0
2019-11-04 12:17:31, Error MIG OC Exception: [0x00000830]
2019-11-04 12:17:31, Error SP Could not restore OC status. Error: 0x8007001F
2019-11-04 12:17:31, Info SP SetupPlatform: Global progress: 20, Phase progress: 69
2019-11-04 12:17:31, Error SP Operation failed: Apply Optional Component status. Error: 0x8007001F[gle=0x000000b7]
2019-11-04 12:17:31, Info SP Operation can retry, we'll attempt to revert its execution.
2019-11-04 12:17:31, Info SP Attempt to revert execution for operation 25
2019-11-04 12:17:31, Info SP The current operation's changes could not be undone, we'll search for operations whose output might have been tainted
2019-11-04 12:17:31, Info SP Will have to revert execution for 35, as its output might have been tainted by the current operation
2019-11-04 12:17:31, Info SP Attempt to revert execution for operation 35
2019-11-04 12:19:39, Info SP Will revert execution for 60, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 114, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 49, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 50, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 51, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 52, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 53, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 66, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 110, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 38, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 24, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 48, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 117, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Will revert execution for 34, as it needed to be executed after the current operation
2019-11-04 12:19:39, Info SP Attempt to revert execution for operation 60
2019-11-04 12:19:39, Error SP Cannot revert execution of operation 60 (Cleanup source WIM file(s)). Execution queue is now compromised.[gle=0x00000012]
2019-11-04 12:19:39, Info SP Cannot revert execution in the queue, this is a fatal error.
2019-11-04 12:19:39, Error SP Operation execution failed: 6. hr = 0x8007001F[gle=0x00000012]
2019-11-04 12:19:39, Error SP ExecuteOperations: Failed execution phase Safe OS. Error: 0x8007001F[gle=0x00000012]
2019-11-04 12:19:39, Error SP CSetupPlatformPrivate::Execute: Execution of operations queue failed, abandoning. Error: 0x8007001F[gle=0x00000012]
2019-11-04 12:19:40, Info Persisting diagnostics data to D:\$WINDOWS.~BT\Sources\Diagnostics\diagnostics.dat
2019-11-04 12:19:40, Info Diagnostics data saved successfully
2019-11-04 12:19:40, Info SP Execution phase [Safe OS] exiting with HRESULT [0x8007001F]
