SOLVED Imaging using other distribution point
  • Thread starter Thread starter dj3094
dj3094
Hello experts,
Is there any way, I can use DP at location x to image a PC at location Y, the reason I want to try this is to test imaging is working at location X. I am imaging PC at my location and it works good and its failing at that location. I check the error logs and it shows below.
Hash could not be matched for the downloaded content. Original ContentHash = AE4B723B3FD41B0C1B351784615D146A6DE4F41CC4A66EEB886C516176C56EDC, Downloaded ContentHash =
DownloadContentAndVerifyHash() failed. 80091007.
I reditributed teh package, I even removed the content from Dp and redistributed it, but it still fails.
Any suggestions?
Regards
AJ
You can do that by adding DP (located at X) to boundary group of Y. With this all the content that computers at Y location request will be served by DP at X. However I think you must first look to fix the DP issues.
kerber
