PENDING HELP!! New to SCCM - v1806 (Test Lab Environment) - TS Error
  • Thread starter Thread starter dgoodrid
dgoodrid
I have set up a test home lab for messing around with SCCM etc..
I have a DC and SCCM server (All Virtual) and they can see/talk etc.. to each other and SCCM loads up all ok.
I have added a Custom Wim image on Windows 10 and boot images, driver packages etc... But can't get either a VM or Physical device to build :(
I have attached a word document with screenshots (Cmtrace error, IP address, Ping server, and the TS showing all 100% on the DP) and also the smsts log in full
As you can see the Packages are all 100% distributed on the DP and that on the VM I get the right IP and can ping anything on that network so but the system just apparently can't find the packages. I have removed the packages and re-added them, and also redistributed them all to no success.
Any suggestions on where to look or what to do would be fantastic
Dave
(SCCM Newbee)
Sorry for the delay, i see that "This task sequence cannot be run because the program files for DEV00008 cannot be located on a distribution point. "
If you're seeing this, it means that the Distribution Point you're talking to is not able find the package referenced. If the package does exist, and/or has been redistributed/verified and the problem persists, then another good place to check, is the Boundary Groups.
QuintonAshmark
