dougwsouza
Dear all,
I'm trying capture a Windows 10 x64 - Build 1809 personalized in a physical machine to import to System Center, but I not be able.
I followed the steps below:
- Equipment is on Workgroup
- Equipment is without sccm client
- Create a Task sequence Media in SCCM
- Extracted the iso file on a removable disk
- Insert the removable disk on the reference computer
- Run the launchmedia.cmd
- After this, I filled all information required on image capture wizard, when i click on finish the image capture wizard closes.
i picked up the logs on %temp%, attached.
Has anyone else had this issue?
