SOLVED Deploy Nero 2017 Burning Rom with Volume licence certificate using SCCM
micdam
i have to create a package / application to deploy to several devices for Nero 2017 Burning Rom Volume licence certificate
i have the serial number and i've downloaded the exe ffile from the official nero web site (the file is Nero_BurningROM2017-1.10.0.6_stub_trial.exe .)
i extract the files but there is no msi file nor the extracted exe file has any setup options.
How can i create the packege incuding the serial number?
Hi micdam,
If you don't have a MSI file, you need to create a custom application with specifying manually the installation settings.
Can you try with this command line:
Code:
Setupx.exe /qb SX SOURCEPATH="C:\Program Files\Nero\Install_files\" CONFIGPATH="C:\Program Files\Nero\Install_files\" SERIALNUMBER="a1a1-a1a1-a1a1-a1a1-a1a1-a1a1-a1a1-a1a1"" REBOOT=""REALLYSUPPRESS"" EULAACCEPTED="1" EXCLUDEAPP="unit_hlp_71,unit_hlp_74,unit_hlp_75,unit_app_15"
Sometimes you won't get the msi file when you extract executable. Try the command line mentioned by @Youssef_S and let us know if it works.
