PENDING CM Client installation issue
Sandip Patil
Hi Prajwal.
i have installed server 2k12 , SQL 2012 SP1 and upgraded in to S2, and SCCM 2012 R2.
I have configured boundaries and boundri group with IP Range. and config discovery as AD system discovery.
i can discover all systems but can see client install on any system also not getting BITs .
Trying to push client over it but its not working .
in services i can see CCMsetup running but after not showing sms agent service in services.
also i have config firewall (Inbond outbond WMI) policy as per your PDF
please help me to solved this issue.
for more details attaching CM logs, win x client logs, and windows 7 client logs.
Thanks Prajwal for your reply.
i have configured DP\MP on the primary site server.
i already created boundary as per you PDF.
please check attached snaps for more details.
---> Created service "ccmsetup" on machine "SPLABWINX01".
---> Started service "ccmsetup" on machine "SPLABWINX01".
Yes I see the ccmsetup is running on the client machine but it has errors finding out the DP locations.
Failed to find DP locations from MP 'SPLABSCCM01.SCCM.COM' with error 0x80004005, status code 404. Check next MP.
in your first screenshot boundary group, i see the site system count is zero. Have you added the site system server to the boundary group ?.
Edit the boundary group > click references tab > check if you have added siste system server at the bottom.
Thanks Prajwal for your response..now client installation issue has been resolved.
i removed DP and re added it..now its working fine.
ChaseMcFadden
