PENDING Building Collections for WMF versions
Kevinlw
My ultimate goal is to get all of our systems, servers and workstations, to WMF 5.1. Building the packages is easy enough. What I am struggling with is reporting and building collections to identify what we have.
The Path:
From what i have read, it will be better to update everything to at least 4.0. Then go to 5.1. That seems to be the easiest route. I have built one package for the purpose to get to 4.0.
My problem.
There just isn't an easy report to get the WMF level. I found something that said to set a default client setting to inventory the powershell.exe file from %windir%\system32\WindowsPowerShell\v1.0 directory. Then build a collection to queryfiles powershell.exe for the correct version number wildcard for the various versions.
My question.
Is this the best way? Does someone have a better way? I need to get all machines and I can deploy and be fairly sure we are good upon successful deployments. However, I really need to get some kind of a report to show management that we are good.
You could enable and use Software Inventory feature in your client settings. By default SINV disables scanning of C:\Windows so you need to re-enable the Powershell path %windir%\System32\WindowsPowerShell\v1.0
After that, you can create Queries or Collections that leverage the "Software Files" attribute class to see what you have.
VenuGopalMantha
