SOLVED WSUS - SCCM Problem (Office 365 Client)
  • Thread starter Thread starter TomTaylor
TomTaylor
Hi all,
i have a problem with my SCCM. In the WSUS-Console i see the "Office 365 Client". In SCCM-Console i hasn't the "Office 365 Client" to select. Sync works. I have Windows Server 2016 , SQL 2016 with latest patch. CM Version is 1902. I has also removed the WSUS-Service and installed it again. Can everybody help me?
BR Tom
On my lab, I can see Office 365 Client on the console.1830
Try to force the sync on the SCCM console and check wsyncmgr.log file if there are any errors.
I sense the sync issues here. Try uninstalling SUP > Install SUP again > Perform Initial Sync > Later check if O365 client option appears under Office.
I uninstall and install the SUP. I have also uninstalled and installed the WSUS. I start the Initial Sync. I checked the logs. The O365 client option don't appears. I attached the log.
emaria
